SS-V: 1170 Stress Concentration of a Plate with Eccentric Hole
Test No. VS18 Find the stress concentration in a plate with eccentric hole.
Definition
Plate is fixed at one end and pressure of 1 psi is applied on the other end of the plate. The units are IPS.
Model Dimensions
a = 1 in
c = 4 in
e = 16 in
a/c = 0.25
e/c = 4
Results
  • σ max   =   kσ nom MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4WdmaaBa aaleaaciGGTbGaaiyyaiaacIhaaeqaaOGaaGPaVlabg2da9iaaykW7 caqGRbGaae4WdmaaBaaaleaacaqGUbGaae4Baiaab2gaaeqaaaaa@4398@
  • K t   ≅   3.25 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWG0baabeaakiaaykW7cqGHfjcqcaaMc8UaaG4maiaac6ca caaIYaGaaGynaaaa@3F25@
  • σ nom   =   1   psi MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4WdmaaBa aaleaacaqGUbGaae4Baiaab2gaaeqaaOGaaGPaVlabg2da9iaaykW7 caaIXaGaaGjbVlaabchacaqGZbGaaeyAaaaa@437E@
The following table summarizes the stress results.
Theory1 SimSolid % Difference
Major principal stress 3.25 3.15 ~3
1 Pilkey, W.D., Pilkey, D.F. and Bi, Z. (1997) Peterson's stress concentration factors. 2nd edn. Hoboken, NJ: John Wiley & Sons, Inc.
